MarkB3108
Jul 29, 2022Follower
Router password reset
Hi there, Does anyone know how to reset a router password? I am trying to reset but am blocked as the security validation says the security answers are not correct (which I know they are correct). An...
CrimpOn
Jul 29, 2022Guru - Experienced User
If you are at the Password Recovery screen because the login password has been rejected three times in a row, then you are screwed.
A Factory Reset is the only way to regain access to the router.
