cpitti
Jul 09, 2021Follower
Router password
What do you do if you try and reset the router password, but it asks you questions for the reset. The questions seem to be not excepting the answers. Is there another way to reset the password.
1 Reply
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
