Noh
Apr 16, 2019Aspirant
Router problem - no network every 1-2 days
I have bought orbi rbr20 for a week. However, every 1-2 days, the router will not be function well, my devices can still connect to the router, but can’t access to network. Sometimes, my desktop even ...
Apr 16, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- NohApr 16, 2019AspirantRouter firmware 2.3.1.44.
Orbi system operate in router mode.
My home size is around 1000 feet.
The distance between the router and satellite is around 12-15 feet.
I am now using auto channel for2.4Ghz. Around 2-4 Wifi Neighbors nearby.
I am using WPA2-PSK security modes .- FURRYe38Apr 16, 2019Guru - Experienced User
What happens if you turn OFF the RBS and just run the RBR alone?
- NohApr 16, 2019AspirantIf i move the satellite to one of my bedroom(may be too many walls between router and satellite), the LED light ring will turn orange. Will it be function well? Thanks.
