Noh
Apr 16, 2019Aspirant
Router problem - no network every 1-2 days
I have bought orbi rbr20 for a week. However, every 1-2 days, the router will not be function well, my devices can still connect to the router, but can’t access to network. Sometimes, my desktop even ...
Noh
Router firmware 2.3.1.44.
Orbi system operate in router mode.
My home size is around 1000 feet.
The distance between the router and satellite is around 12-15 feet.
I am now using auto channel for2.4Ghz. Around 2-4 Wifi Neighbors nearby.
I am using WPA2-PSK security modes .
Apr 16, 2019Guru - Experienced User
What happens if you turn OFF the RBS and just run the RBR alone?
30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
- NohApr 16, 2019AspirantIf i move the satellite to one of my bedroom(may be too many walls between router and satellite), the LED light ring will turn orange. Will it be function well? Thanks.
- FURRYe38Apr 17, 2019Guru - Experienced User
12-15 feet is too close to the RBR with the satellite.
Try turning off the RBS and see if the system continues to stop working every 1-2 days or this doesn't happen anymore.
