Noh
Apr 16, 2019Aspirant
Router problem - no network every 1-2 days
I have bought orbi rbr20 for a week. However, every 1-2 days, the router will not be function well, my devices can still connect to the router, but can’t access to network. Sometimes, my desktop even ...
ekhalil
Apr 16, 2019Master
Noh wrote:
I have bought orbi rbr20 for a week. However, every 1-2 days, the router will not be function well, my devices can still connect to the router, but can’t access to network. .....
- When this happens, does the Orbi Router's top LED ring lights magenta?
- When this happens please login to the Router's IP address (not orbilogin.com as this will probably not work) and check in the web GUI under >> ADVANCED >> INTERNET PORT >> CONNECTION STATUS >>
Noh
The LED light ring function as normal in white color. I will check the connection status through ip address next time, thanks.
