rhwd2003
Mar 08, 2020Tutor
Router Randomly Dropping Internet Connection
I am coming to this forum with a month long problem. FIrst let me explain my environment: Residential Brick House 2 Floors 3k Square foot Spectrum Internet 200 up / 10 down Arris SURFboard SB...
rhwd2003
Mar 11, 2020Tutor
Thanks for all of the replies and great info. I have not made any changes yet but turning on the logs, I wanted to see the logs before I started making too many changes. My internet is dropping multiple times a day now, like even multiple times an hour. When the internet drops, I am losing ethernet connection too instead of just wifi now that I have the orbi system.
When the internet drops, what should I look for in the logs? Here's what the logs looks like over the last couple hours when I have had internet drops...
[WLAN access rejected: incorrect security] from MAC address d8:c4:97:c2:9d:a4, Wednesday, March 11, 2020 15:18:22
[admin login] from source 192.168.1.2, Wednesday, March 11, 2020 15:18:21
[WLAN access rejected: incorrect security] from MAC address d8:c4:97:c2:9d:a4, Wednesday, March 11, 2020 15:00:48
[DHCP IP: 192.168.1.9] to MAC address 2c:d9:74:b7:08:98, Wednesday, March 11, 2020 14:59:56
[WLAN access rejected: incorrect security] from MAC address d8:c4:97:c2:9d:a4, Wednesday, March 11, 2020 14:55:19
[DHCP IP: 192.168.1.12] to MAC address c0:d2:f3:63:0c:c6, Wednesday, March 11, 2020 14:55:12
[WLAN access rejected: incorrect security] from MAC address d8:c4:97:c2:9d:a4, Wednesday, March 11, 2020 14:42:10
[DHCP IP: 192.168.1.4] to MAC address b8:53:ac:41:f7:26, Wednesday, March 11, 2020 14:41:33
[WLAN access rejected: incorrect security] from MAC address d8:c4:97:c2:9d:a4, Wednesday, March 11, 2020 14:39:59
[DoS Attack: SYN/ACK Scan] from source: 89.163.135.7, port 443, Wednesday, March 11, 2020 14:29:07
[DHCP IP: 192.168.1.32] to MAC address 2c:54:91:de:44:7f, Wednesday, March 11, 2020 14:20:33
[WLAN access rejected: incorrect security] from MAC address d8:c4:97:c2:9d:a4, Wednesday, March 11, 2020 14:18:27
[DHCP IP: 192.168.1.5] to MAC address d0:4f:7e:5e:de:1c, Wednesday, March 11, 2020 14:01:19
[DHCP IP: 192.168.1.22] to MAC address a4:f1:e8:b0:b8:62, Wednesday, March 11, 2020 13:59:27
[WLAN access rejected: incorrect security] from MAC address d8:c4:97:c2:9d:a4, Wednesday, March 11, 2020 13:57:17
[DoS Attack: RST Scan] from source: 220.181.38.148, port 80, Wednesday, March 11, 2020 13:56:47
[DHCP IP: 192.168.1.3] to MAC address 38:94:ed:bf:c4:39, Wednesday, March 11, 2020 13:56:05
[DoS Attack: RST Scan] from source: 173.194.77.26, port 25, Wednesday, March 11, 2020 13:55:20
[Time synchronized with NTP server] Wednesday, March 11, 2020 13:55:16
[Initialized, firmware version: V2.5.1.8] Wednesday, March 11, 2020 13:55:02
- FURRYe38Mar 11, 2020Guru - Experienced User
I see more of these entries:
"[WLAN access rejected: incorrect security] from MAC address d8:c4:97:c2:9d:a4, Wednesday, March 11, 2020 14:42:10"
I would check your devices for this MAC address> d8:c4:97:c2:9d:a4
- AnonymousMar 11, 2020
[Initialized, firmware version: V2.5.1.8] Wednesday, March 11, 2020 13:55:02who did this? You or NG?
- rhwd2003Mar 15, 2020Tutor
That was a device restart. I just had the internet drop 10 minutes ago and I looked at the connection stats and I see that the router actually rebooted itself. The logs got replaced and the connection stats says that its only been up for 10 minutes. Now that I can see that the router is rebooting each time I lose the internet. Where do I start next?
- FURRYe38Mar 15, 2020Guru - Experienced User
I would start by turning OFF ALL Wired and wireless devices accept for 1 wired PC. Watch the behavior of the RBR to see if the RBR reboots any. I would power OFF the ISP modem and RBR for 30 seconds then back on. Watch the behavior with the 1 PC. If you don't notice anything. Start by adding a device. One at a time. Watch the behavior. See if anything changes after devices start connecting...
rhwd2003 wrote:That was a device restart. I just had the internet drop 10 minutes ago and I looked at the connection stats and I see that the router actually rebooted itself. The logs got replaced and the connection stats says that its only been up for 10 minutes. Now that I can see that the router is rebooting each time I lose the internet. Where do I start next?
