Mikepaulik's avatar
Mikepaulik
Follower
Jul 27, 2019
Router rbk43 200nas
iPads, iPhones, computers continually lose Wi-Fi Internet connection. Satellites lose sync even though they are coast to the base station and modem . 20 and 50 feet away Adam is a Netgear CM 700
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Mikepaulik
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
    Blanca
    Community Team
