Lavolpe
Jun 10, 2018Aspirant
Router restarts itself
For about a month now my Router will shut down and restart on its own. My connection speed also drops from about 120 mbps to 40mbps. Any help is appreciated. If there is any thing else needed please ...
Jun 11, 2018Guru - Experienced User
Any wifi neighbors near by? If so, how many?
What channels are you using on the router? Try 1, 6 or 11 on 2.4Ghz.
Set WPA2 and AES only.
Are wired speed tests with a PC and browser any good?
What wireless devices are you testing wireless speeds with?
Besure your ISP serivces are working well and the modem is working well. Have the ISP check signal levels up to the modem.
Lavolpe
Jun 11, 2018Aspirant
It is set to WPA2 and AES only. I am using my desktop pc wireless to test my connection. My modem is showing that it is all well. When I go to check what happened after my signal drop my modem shows that all lights are on. But the orbi is restarting as in it is pulsing white. As for the channel I left it on auto.
