Lavolpe
Jun 10, 2018Aspirant
Router restarts itself
For about a month now my Router will shut down and restart on its own. My connection speed also drops from about 120 mbps to 40mbps. Any help is appreciated. If there is any thing else needed please ...
Jun 11, 2018Guru - Experienced User
Might try the following. Re-load the same FW file again. This time, do a factory reset of the Orbi router and set up from scratch.
Leave the satellite turned off.
Test the Orbi router along with your PC, do both wireless and wired speed tests with a browser.
- LavolpeJun 11, 2018Aspirant
I tried doing a full reset went through the setup and about 20 min afterwards it did it again.
I appreciate the help.
