Lavolpe
Jun 10, 2018Aspirant
Router restarts itself
For about a month now my Router will shut down and restart on its own. My connection speed also drops from about 120 mbps to 40mbps. Any help is appreciated. If there is any thing else needed please ...
Jun 12, 2018Guru - Experienced User
Does the same thing happen on 2.4Ghz if you can get it to connect there?
What is the Mfr and model# of the wireless adapter in this PC?
Try changing manual channels on 5Ghz as well.
Did you disable MIMO, Daisy Chaing and Fast Roaming on the router, save settings and reboot?
