tc1876
Aug 12, 2018Tutor
Router show no internet communications,but satellite broadcast Internet just fine
Rbk22 router states no internet connection and can't get internet via any device, but satellite has internet connection and works just fine with all devices. Did a reset on the router, but no change....
- Aug 15, 2018
Let us know how the new one does. Ya, seems like the router base is faulty.
tc1876
Aug 13, 2018Tutor
Yes, the Mac gets an IP address and connects to the internet via the LAN cable from the router with no problem.
A factory reset was completed from scratch that made me setup the router and satellite. Same situation occurs with no wi-fi broadcast from the router, but wi-fi broadcasts from the satellite.
Aug 14, 2018Guru - Experienced User
So if you turn OFF the satellite, you can't see any broadcast wifi or connect to the Orbi base by it self?
I would make contact with NG support about this. The base router may need to be replaced...
