tc1876
Aug 13, 2018Tutor
Router show no internet communications,but satellite broadcast Internet just fine
Rbk22 router states no internet connection and can't get internet via any device, but satellite has internet connection and works just fine with all devices. Did a reset on the router, but no change....
- Aug 15, 2018
Let us know how the new one does. Ya, seems like the router base is faulty.
Aug 14, 2018Guru - Experienced User
So if you turn OFF the satellite, you can't see any broadcast wifi or connect to the Orbi base by it self?
I would make contact with NG support about this. The base router may need to be replaced...
tc1876
Aug 15, 2018Tutor
Yes, so if I turn off the satellite, there is no broadcast wi-fi in the whole house nor can I connect to the Orbi base by itself. Since I bought this at Costco, I'm going to return it there and get another. I agree with you that the base router seems to have malfunctioned. Thanks again for your help and timely replies.
- FURRYe38Aug 15, 2018Guru - Experienced User
