GTPprix
Mar 06, 2018Star
Router solid Magenta in AP Mode - Fix yet?
So in the interest of not being "that guy" I've just read through basically every post I can find concerning this and still have no resolution that I can find. I've got an Orbi Router in AP mode ...
GTPprix
Mar 06, 2018Star
That doesnt seem to work in my configuration, the Main Router(AP in my case) is plugged into a large Cisco switch not a cable modem.
st_shaw
Mar 06, 2018Master
I don't know why that would matter. The Orbi instructions say to connect to the Yellow Internet (WAN) port in AP mode. My Orbi is in AP mode, and the Yellow Internet port is connected to a Ubiquiti switch, which is then connected to my router.
Maybe power-cycle things after moving the cable to the WAN port?
If you have to leave your cable connected to a LAN port, I read that you can connect anything to the Orbi WAN port and the light should go out, as long as a link is established.
- GTPprixMar 06, 2018Star
I saw that and tested it with no joy, will give that a go again tonight and see if it actually works this time :)
- FURRYe38Mar 06, 2018Guru - Experienced User
What is the model # of the Cisco switch? Managed or un-managed type of switch?
GTPprixwrote:I saw that and tested it with no joy, will give that a go again tonight and see if it actually works this time :)
Its an SG300-P series managed
- kolellaMar 07, 2018Apprentice
What happens if you connect both ports simultaneously (WAN and LAN1) to your router/switch?
- Random12Mar 07, 2018Apprentice
Yes, plugging in the WAN port fixes it for me. If I plug in both the WAN and LAN ports it appears to be working OK, but I'm not using Ethernet backhaul.
