GTPprix
Mar 06, 2018Star
Router solid Magenta in AP Mode - Fix yet?
So in the interest of not being "that guy" I've just read through basically every post I can find concerning this and still have no resolution that I can find. I've got an Orbi Router in AP mode ...
Mar 06, 2018Guru - Experienced User
What is the model # of the Cisco switch? Managed or un-managed type of switch?
GTPprixwrote:I saw that and tested it with no joy, will give that a go again tonight and see if it actually works this time :)
GTPprix
Mar 06, 2018Star
Its an SG300-P series managed
- FURRYe38Mar 06, 2018Guru - Experienced User
This could be the issue. Managed switched have additional features that maybe enabled or inhibiting full access. To test this, directly conenct the Orbi AP mode router to the main host router directly and see the LED remains or fully got out. If so, then something in the managed switch is keeping the Orbi router from fully connecting with data services with the main host router.
Have a non managed switch to test with? A non managed switch is more like a dumb switch, just data all data to where it needs to go with out any filters or configurations.
You might review any support information regarding your model switch to see if there is anything that can be disabled on this switch that would interfere with normal network traffic.
https://www.cisco.com/c/en/us/support/switches/sg300-10-10-port-gigabit-managed-switch/model.html
GTPprixwrote:Its an SG300-P series managed
- GTPprixMar 06, 2018Star
Yup I've got a couple to test with just didnt see anything in the logging on the switch so kind of ruled it out (until today) thank you! :)
