hnevis
Dec 11, 2018Aspirant
Router speed
I have the above router + ORBI74 satelilite. Purchased mid 2017.
I upgraded to gigabit speed. I get that speed hardwired to the modem. However the Orbi system gives me 100-150 mbps. Firmware is ...
- Dec 11, 2018
Good Luck.
Dec 11, 2018Guru - Experienced User
Which Orbi router do you have?
Has a factory reset been performed then setup from scratch and run a speed test with a wired PC connected to the router?
