hnevis
Dec 11, 2018Aspirant
Router speed
I have the above router + ORBI74 satelilite. Purchased mid 2017.
I upgraded to gigabit speed. I get that speed hardwired to the modem. However the Orbi system gives me 100-150 mbps. Firmware is ...
- Dec 11, 2018
Good Luck.
hnevis
FURRYe38 wrote:
Which Orbi router do you have?
Has a factory reset been performed then setup from scratch and run a speed test with a wired PC connected to the router?
Thank you!
The modem is a Rohs C3000. The router and satelite are RBR50.
I did a factory reset on both.
With a wired connection to the Orbi router I get 626mbps download.
Through the satelite I now get 50-60 mbps, less than I got before.
Exasperating!
Dec 11, 2018Guru - Experienced User
Is the satellite wireless or wire connected to the base router?
Are you wireless or wired to the satellite when speed testing?
Remove the Orbi74 satellite and test with the ones that came with the newer Orbi system.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
- hnevisDec 11, 2018Aspirant
My home is 2900 square feet.
The satelite is not hard wired to the base. It sits 25 feet from the base but there is a wall between them.
I will try to locate a newer satelite.
Thank you,
Very helpful.
