hnevis
Dec 11, 2018Aspirant
Router speed
I have the above router + ORBI74 satelilite. Purchased mid 2017.
I upgraded to gigabit speed. I get that speed hardwired to the modem. However the Orbi system gives me 100-150 mbps. Firmware is ...
- Dec 11, 2018
Good Luck.
hnevis
My home is 2900 square feet.
The satelite is not hard wired to the base. It sits 25 feet from the base but there is a wall between them.
I will try to locate a newer satelite.
Thank you,
Very helpful.
