aviater
Oct 03, 2017Follower
Router to Orbi signal
Hi, I have setup the router to AP mode and connected to my R7000. Everything works fine as both the Orbi router and satellite are connected with LED off. I login to the satellite. Go to Status and fo...
DarrenM
Oct 05, 2017Sr. NETGEAR Moderator
You may just need to move the satellite around until you find the best signal.
DarrenM
