r_pathak5
Jan 03, 2022Guide
Router UPS Ratings
I am looking for compatible router UPS options for the RBK753 router and satellites. Would any UPS supporting 12V - 2A work ?
- Jan 03, 2022
Rarely does the router need their max output from the power supply. So it might work but have instability issues/rebooting.
always better to have more amperage as the router won't draw the additional power unless it needs it.
r_pathak5
Jan 03, 2022Guide
Yes I am looking for a UPS, but I am looking for sleeker inline UPS options instead of a full blown UPS. Inline UPS's that support 12V 2A are pretty sleek and was wondering if those would work with this.
Jan 03, 2022Guru - Experienced User
If it matches the power supplies output (same voltage and polarity, with enough amperage) then it should work.
What specific model are you looking at?
The inline models might be sleeker but a bit more expensive.
- r_pathak5Jan 03, 2022Guide
Looking for something like this
- plemansJan 03, 2022Guru - Experienced User
You can have more amps but don't go less. And even on that models site, they recommend going up a bit. They've put if you're needing 0.5A to go with the 1.0A version. I'm betting they slightly underperform or are needing extra amperage to account for charging/conversion loss.
So check what your actual adapter is outputing for voltage and amps and just make sure it has the exact same volts and at least the same (if not more) amps.
On the website it is written that the RKB753 comes with the 12V , 2.5A adopter. So I am assuming that 2A UPS will not work
