creaky's avatar
creaky
Star
May 04, 2017
Router V1.9.1.12, satellite V1.8.0.6
My firmware was automatically updated before I could do it manually and the router and satellite are evidently on different versions of the firmware. Things are working OK now; is there any risk to updating the satellite firmware manually to 1.9.1.12 though it's recommended to update the satellite first when performing updates?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello creaky
    You should manually update the satellite if it will not update on the auto update.
    DarrenM
