dangitzin
Apr 02, 2019Aspirant
Router vs AP mode
Which is better? I’m currently using router mode. Will AP mode still allow me to use the LAN ports on the satellites to connect my PCs and consoles? I’ve tried AP mode before but the ports stopped wo...
dangitzin
Apr 03, 2019Aspirant
The Arris Gateway is a modem/router I just can’t remember off the top of my head the model# and it does all the things that the Orbi does, and more. I can actually set which devices are take priority (low, med, high) like in normal NG routers.
As for the security feature, the gateway was provided by my ISP, they didn’t go over anything about the gateway. Just installed it and that was it. I’m thinking somewhere in the lines of ddos protection or firewall that I turned off. Just I’d have to log back in just to check.
I really want to just put Orbi to AP mode, but last I tried I couldn’t use the lan ports on the back of the satellites. Is that one of the things I lose putting it in AP mode?
michaelkenward
Apr 03, 2019Guru - Experienced User
No. I have an Orbi on AP mode. The LAN ports work just fine.
Sound like the same as you get on the Orbi.
