dangitzin
Apr 03, 2019Aspirant
Router vs AP mode
Which is better? I’m currently using router mode. Will AP mode still allow me to use the LAN ports on the satellites to connect my PCs and consoles? I’ve tried AP mode before but the ports stopped wo...
SW_
Apr 04, 2019Prodigy
>> But whenever I try to connect the PS4 back to the Orbi satellite...
This is connected to Satellite via wireless, right?
If yes, then the wireless backhaul isn't the issue. It's the issue with PS4 WiFi & Satellite wireless connection.
dangitzin
Apr 04, 2019Aspirant
No, I’m using an Ethernet to connect to the satellite
- SW_Apr 04, 2019Prodigy
So that rules out backhaul issue and wireless issue. That also rules out the LAN ports on Satellite issue since powerline works when connecting to the LAN port.
Are you using the same LAN cable that's used with the powerline or a different eithernet cable when connecting to the Satellite LAN port? If it's different cables, try to use the same cable that works with powerline. If you are using the same cable, make sure you connect PS4 to the same LAN port that was used by the powerline.
- dangitzinApr 04, 2019Aspirant
It's the same cable. My powerline and this orbi satellite is are easily accessible. Also I've ping'ed google being connected to the RBR and then the RBS. Did about 5 times each and got roughly simliar results to this on both:
Pinging www.google.com [172.217.11.164] with 32 bytes of data
Reply from 172.217.11.164: bytes=32 time=48ms TTL=252
Reply from 172.217.11.164: bytes=32 time=29ms TTL=252
Reply from 172.217.11.164: bytes=32 time=26ms TTL=252
Reply from 172.217.11.164: bytes=32 time=20ms TTL=252Ping statistics for 172.217.11.164:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 20ms, Maximum = 48ms, Average = 30ms - dangitzinApr 04, 2019Aspirant
If you are using the same cable, make sure you connect PS4 to the same LAN port that was used by the powerline.Didn't see this... the "base" of the powerline is connected to one of the RBR's ethernet ports and the receiving plug is straight into the wall outlet. Only thing connected to the satellite's ports are my PC, Xbox One X and sometimes the PS4 Pro when I try to test it out again.
>> the "base" of the powerline is connected to one of the RBR's ethernet ports...
This basically answers your question. The issue is with the wireless backhaul. To avoid this problem, add a 4-ports Gbits switch and connect the switch to the powerline if you need more LAN ports. Then connect all your consoles to that switch until you have time to experiment with wireless backhaul solution by moving it around to find a better location. You can also try switching to using LAN backhaul via the powerline if that gives you better performance than wireless backhaul. In the worst case, you can try a Factory Reset on both the router and satellite and start all over again when no one else is around.
Have you tried/checked these settings?
>> Disable 20/40 MHz Coexistence
>> Enable WMM (Wi-Fi multimedia) settings
- FURRYe38Apr 04, 2019Guru - Experienced User
Also I would disable Instant ON with the xbox console as well...
