fdease12
Apr 11, 2020Aspirant
Router will not accept internet from confirmed modem
Orbi will not accept Internet from Comcast, modem pinged/updated/confirmed it has connectivity. Orbi will not grab it, 2 hours on the phome with Comcast.. (RBK50V-100NAS)
Apr 12, 2020Guru - Experienced User
Be sure to power OFF the MODEM for 30 seconds then back on. Do same for RBR. Check internet.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
fdease12 wrote:Orbi will not accept Internet from Comcast, modem pinged/updated/confirmed it has connectivity. Orbi will not grab it, 2 hours on the phome with Comcast..
(RBK50V-100NAS)
