JakeBamat
Feb 02, 2018Aspirant
Router will not connect to internet
Worked fine for months. Woke up and the router was not connected to the internet. Tried all the troubleshooting methods (reset button, disconnecting power cords, etc.) including power reset of Soni...
DarrenM
Feb 05, 2018Sr. NETGEAR Moderator
Have you tried a factory reset of the unit by holding the reset button for 10+ seconds?
DarrenM
JakeBamat
Mar 02, 2018Aspirant
Any other ideas? Same issue is occurring and I can't get beyond it.
- FURRYe38Mar 03, 2018Guru - Experienced User
Whats the Mfr and model of the ISP modem? Built in router by chance?
Swap ethernet cables beween modem and router to test.
- JakeBamatMar 03, 2018Aspirant
I have Sonic Gigabit Fiber Internet. Everything works fine with the ethernet cables. Swapping them is going to take about an hour to re-run the ethernet line through my garage and unit walls.
I can plug my Sonic model directly into a laptop via ethernet and get internet. I can also pull out the ethernet cable from the Orbi and connect it back into my old Apple Time Machine router and the wireless fires up perfectly. So the issue doesn't appear to be my ISP or the cables.
You may have a faulty or bad router unit. I would try another unit and see if you can. Return the current unit to place of purchase.
JakeBamatwrote:I have Sonic Gigabit Fiber Internet. Everything works fine with the ethernet cables. Swapping them is going to take about an hour to re-run the ethernet line through my garage and unit walls.
- RogerSCMar 03, 2018Virtuoso
When my Orbi wouldn't connect to the internet, I changed the Orbi's MAC Address to that of my desktop PC. First I verified that I could connect the PC directly to the modem and have internet active, and then changed the MAC Address of the Orbi to that of the PC, and that allowed the Orbi to connect to the internet. As I recall, the MAC Address setting is in with the WAN configuration, but I'm not sure about that at the moment. Anyways, find a client that will connect to the internet when connected directly to the modem (without the Orbi, just connected to the modem) like a desktop or laptop PC, and then change the MAC Address of the Orbi to that client's MAC Address. You'll be able to go back to the native MAC Address of the Orbi at some point, but give that a try.
Hope that it helps.
