mukherjeeprabal's avatar
Aug 07, 2021
Router WNR614- Old router to replace with ORBI AC3000
Hi, need to replace the old router (WNR614) having cable connection of Alliance broadband, want to replace with AC3000 Orbi Mesh, please suggest the procedure.   Thanks
  • FURRYe38's avatar
    Did you actually remove the old router and replace it with the new RBR and power OFF the ISP modem for 1 minute then back on?
    Does your ISP require any user account information or entry on the old router that the new router needs?
    Make contact with the ISP to have them help you get the new router online with there modem.
    Follow the online user guide and manuals to get the Orbi online...
