grumpy63's avatar
Jun 16, 2019
router won't connect to modem
I recently moved and recieved a new modem from specrtrum. i have an older netgear router that will connect to modem fine.  My orbi will not connect to the internet. any suggestions?
  • grumpy63's avatar
    grumpy63
    Jun 18, 2019
    I got it connected. Thanks for your reply. I had to delete and reinstall the app in order to re set up the router. All is good. Thanks again.
