grumpy63
Jun 16, 2019Tutor
router won't connect to modem
I recently moved and recieved a new modem from specrtrum. i have an older netgear router that will connect to modem fine. My orbi will not connect to the internet. any suggestions?
- Jun 18, 2019I got it connected. Thanks for your reply. I had to delete and reinstall the app in order to re set up the router. All is good. Thanks again.
ekhalil
Jun 16, 2019Master
- Are you able to access internet when you connect a computer directly to the modem?
- When you connect Orbi to the modem, will the LED ring on the Orbi Router light any color? Does the LED ring color change if Orbi is connected or not?
- Are you able to connect to the Orbi web GUI by browsing to 192.168.1.1 or orbilogin.com?
grumpy63
Jun 18, 2019Tutor
