dpremo
Jun 04, 2019Follower
Router wont connect
Our Router light remains white and will not connect to our wireless modem
Jun 05, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
When setting up with a modem be sure to turn OFF both modem and RBR first for 30 seconds, then power ON the ISP modem first then power ON the RBR. I would factory reset and have a wired PC connected to the back of the RBR, with a web browser walk thru the setup wizard. Besure to write down all important information for safe keeping.
Ensure your using a good quality LAN cable between the modem and RBR. CAT6 is recommended.
dpremo wrote:Our Router light remains white and will not connect to our wireless modem
