gearcommune
May 15, 2021Aspirant
Routerlogin.net certificate “not trusted” IoT devices (tv and others) cannot use WIFI
This has been going on for months and have not found answers!!! I have Orbi RBR50v2 and as devices are using the wifi there are times in the background it tries to connect routerlogin.net. It won't...
Lyth
Jul 21, 2021Guide
I took a chance 2 weeks ago and updated to the latest firmware 2.7.3.22. I have had access control on and working correctly since. I hate to jinx it even saying this as sometimes I've had it work for a month, then decide to start blocking everything.
Lyth
Aug 09, 2021Guide
Lyth wrote:I took a chance 2 weeks ago and updated to the latest firmware 2.7.3.22. I have had access control on and working correctly since. I hate to jinx it even saying this as sometimes I've had it work for a month, then decide to start blocking everything.
And sure enough today the router decided to block all devices again SMH
- FURRYe38Aug 09, 2021Guru - Experienced User
Are you setting IP address reservations for devices, then enabling Access Controls?
- LythSep 03, 2021Guide
Yes, I started clean. Like other firmware releases, it seems to work for a couple of months before it goes rogue. I disabled access control after this happened and just this week the router crapped out. Same thing happened to me more than once now. Can't access the router, no internet access, and can't reset with the button on the router. Had to TFTP the firmware to get it back up. I've had this setup for at least 3 years and the first 2 years it worked flawlessly. The more recent firmware releases have not been kind to my Orbi.
- FURRYe38Sep 04, 2021Guru - Experienced User
Downgrade back to what worked for you then.
