farmboy3000
May 17, 2020Star
Routerlogin.net digital certificate expired
I have an RBR40 that is blocking my wife's iphone7 due to an expired security certificate for routerlogin.net. All other phones work fine. I updated the Orbi firmware to the latest v2.3.5.32 hoping...
- May 25, 2020
Well, I finally got back to troubleshooting this issue and discovered that her phone was set to "blocked" on the router for some reason. I changed it to "allow" and it's all good now. Not sure how it got set to "blocked". It would be nice to get a more descriptive error message to help with troubleshooting. Thanks for your help all!
CrimpOn
May 17, 2020Guru - Experienced User
Yes, Netgear's SSL certificate has been a mess since last August.
How is this "blocking" the iPhone? Can the phone not access the internet? If you open Safari and enter http://ibm.com, does the web page not open?
farmboy3000
May 17, 2020Star
Correct, the phone cannot connect to the internet using wifi. Any website it attempts to open results in a "err_ssl_protocol_error", which I was able to trace to the expired security certificate.
- CrimpOnMay 17, 2020Guru - Experienced UserIs there an option in tiny print somewhere to "ignore the warning, go to the site"?
- farmboy3000May 17, 2020Star
Nope, it's a dead end. Attached are a couple of screenshots of Chrome.
Another screen shot.
