SteCar
Jul 23, 2019Follower
ROUTER/SATELlITE COMPATIBLITY
 Can you please tell me which Orbi Satellites are compatible with the Orbi RBR 40 router? I have the RBK 43 mesh system and looking to add another satellite?  thanks  stecar
- Jul 23, 2019
Most RBS20,30 and RBWs are compatible. Even the RBSY outdoor is compatbile though the back haul rate wont be as good as if it was connected to a Orbi 50 series system. You can even connect a RBS50 to a RBR40. Again the backhaul will not be as good as the 50 series system. It works though.
SteCar wrote:Can you please tell me which Orbi Satellites are compatible with the Orbi RBR 40 router? I have the RBK 43 mesh system and looking to add another satellite?
thanks
stecar
Jul 23, 2019Guru - Experienced User
thanks
stecar
