motal6141
May 05, 2019Aspirant
Routeur forces Daisy Chain while disabled
Hello all :
i have a router RBR50 and 2 satellites RBS50, Daisy-chain topology unchecked.
i suffer from regular wifi drop offs : when checking my network mapping, it seems that my network...
ekhalil
May 05, 2019Master
When Daisy Chain is disabled then you should only see one hidden backhaul network originated from the router. If Daisy Chain is enabled then you will see one hidden network from each of the Satellites as well.
Please make a wifi scan using a laptop or a mobile device. If you see any hidden network from any of the Satellites (Check the MAC addresses to see which Satellite is which) then please restart or power cycle that Satellite. It could be that the parameter change when you disabled Daisy Chain was not passed to the Satellite from the Router for some reason (e.g. bad link).
It’s this hidden network that allows Satellites to connect to the Router (in star topology) or other Satellites (in Daisy Chain topology).
SW_
May 05, 2019Prodigy
Or point your browser at each Satellite debug.htm page. Verify that Daisy-Chain is indeed disabled on that page.
Replace 192.168.1.x with Satellite IP address:
