Harripeters
Oct 31, 2019Aspirant
RSB50Y Orbi outdoor booster keeps dropping out
I’ve installed 6x of the RSB50Y orbi outdoor universal satelite units around the house. I have gone through the setup process and had it all working with the blue light staying on to indicate good con...
Oct 31, 2019Guru - Experienced User
What model router do you have them connecting too? Orbi? Or something different?
- HarripetersOct 31, 2019Aspirant-I’m not sure about the firmware. We just used the app to sync them back in March this year. Not sure about any updated firmware?
-it’s currently connected to a Telstra modem router. Just a standard issue one provided by the internet provider. It’s not orbi.
-the first booster is located roughly 10ft from the router and is in the ceiling space. It’s a big open ceiling space about 8ft high. There are also 3x more boosters located in the same ceiling space and they are roughly 80-90ft away from the booster closest to the router.
There isn’t anything in between them it’s pretty much a clear path between boosters just in the ceiling.
-I didn’t even know about channels so I will check that out.
- there are 2 neighbours either side of the home. They both have wifi that can be reached from our place.
