Rdub-mongoose
Dec 21, 2022Tutor
RWB30 no power
I think I know the answer which is my satellite is toast but figured I would check here. My router is working fine. It dropped the connection to the satellite. I tried to reset the satellite multiple ...
Dec 22, 2022Guru - Experienced User
You're a little caught because the RBW30 is the only one that doesn't have an ethernet port to revive them if they get corrupt firmware or power.
Does the power light even come on at all?
did you try a 30/30/30 reset? (hold reset for 30 seconds while powered on, continue to hold reset for 30 seconds while powered off, continue to hold for 30 more seconds while powering it back on)
Rdub-mongoose
Dec 22, 2022Tutor
Thanks for the reply. I had done the 30 sec reset but didn’t know about the 30/30/30. Just tried it with no luck. I guess I have a brick that is plugged into my outlet.
- plemansDec 22, 2022Guru - Experienced User
Does the power light come on at all?
- Rdub-mongooseDec 22, 2022Tutor
The light never comes on.
If its out of warranty and the light isn't even coming on, I'd take a chance at opening it up and see if one of the prongs has come disconnected. I've had that happen to a device before and it was simply soldering it back on and it worked. And if not, you're not out anything.
