Rdub-mongoose
Dec 21, 2022Tutor
RWB30 no power
I think I know the answer which is my satellite is toast but figured I would check here. My router is working fine. It dropped the connection to the satellite. I tried to reset the satellite multiple ...
Rdub-mongoose
Dec 22, 2022Tutor
Thanks for the reply. I had done the 30 sec reset but didn’t know about the 30/30/30. Just tried it with no luck. I guess I have a brick that is plugged into my outlet.
Dec 22, 2022Guru - Experienced User
Does the power light come on at all?
- Rdub-mongooseDec 22, 2022Tutor
The light never comes on.
- plemansDec 22, 2022Guru - Experienced User
If its out of warranty and the light isn't even coming on, I'd take a chance at opening it up and see if one of the prongs has come disconnected. I've had that happen to a device before and it was simply soldering it back on and it worked. And if not, you're not out anything.
