danall22
Apr 02, 2020Aspirant
S10 and Orbi drop out
I have an Orbi set up running in router mode and it does not like the s10. I have over 50 devices attached and not one issue with any of the others but the s10 is constantly disconnecting from the Orb...
Retired_Member
Apr 02, 2020s10?
- danall22Apr 02, 2020AspirantYes sorry a Samsung s10 mobile phone.
- FURRYe38Apr 02, 2020Guru - Experienced User
Try doing a IP address reserveration for the phone ON the RBRs web page. Use a web browser for this.
See if you can assign it a IP address reservation.
You can try some of these suggestions, however you may not want to both since other devices are working. You can revert back the changes:
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).- Retired_MemberApr 02, 2020
no mention of the firmware?
