danall22
Apr 02, 2020Aspirant
S10 and Orbi drop out
I have an Orbi set up running in router mode and it does not like the s10. I have over 50 devices attached and not one issue with any of the others but the s10 is constantly disconnecting from the Orb...
danall22
Yes sorry a Samsung s10 mobile phone.
Apr 02, 2020Guru - Experienced User
Try doing a IP address reserveration for the phone ON the RBRs web page. Use a web browser for this.
See if you can assign it a IP address reservation.
You can try some of these suggestions, however you may not want to both since other devices are working. You can revert back the changes:
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
- Retired_MemberApr 02, 2020
no mention of the firmware?
