Chuck_M
Jan 12, 2019Mentor
Same Model System, Different Behavior??
I had recently posted on here that although my Orbi system was running well, the Orbi app would not list devices under the "Network Map" option. I have tried all sorts of things to get this to work ...
- Jan 13, 2019
SOLVED ISSUE Of Network Map Not Rendering Properly and Showing Devices By Connection On Android!!!!!!!
BLUF: My original local SSID was "Daily Planet" The Space in the SSID was preventing the "CONNECTION TYPE" and "CONNECTED ORBI" fields from being reported to the Orbi App! (My neighbors SSID is only 4 characters long with no spaces so theirs worked properly)
This only affected Android devices running the Orbi App... Not Apple Devices
Process I took per FURRYe38 recommendation:
- Disconnected satellites (2 of them)
- Hard reset Router
- Rebooted & initial set up
- Tested (It didnt work since I used my original SSID "Daily Planet")
- Reverted to an Earlier Firmware version thinking that may help -- rebooted and set up but used the default SSID (ORBI38)
- Noticed all was working properly!
- Changed SSID to "Daily Planet"
- Noticed it DIDNT WORK again with an SSID with a space in it
- Changed SSID to "Daily_Planet"
- Noticed it was working properly!
- Updated Firmware to current version
- Verified it is still working properly on all android devices.
- Turned back on Satellites
- Updated Settings for Reserved IPs etc and reattached wireless devices with new SSID
- Poured myself a cocktail and am a happy man!
Orbi and the Orbi APP CANNOT HANDLE SSID's with spaces in them. They will not render the network map properly if so.
To resolve: Take out the spaces -- replace with underline and it should work properly!!!!!!
A couple of heroes out there who deserve recognition for helping & discussing this
Pass the word. If you have spaces in your SSID, Android phones will not render the Attached devices properly under the DEVICE LIST nor the NETWORK MAP!
Chances are, someone ought to report this to the Orbi App Folks and this solution should be pinned at top for reference
JoeCymru
Jan 12, 2019Virtuoso
The mystery is why it worked with your friend's recent purchase, and not for many many others. My app experience with the network map is slightly different in that my backhaul is wifi. The two solid lines on your example are dashed on mine (dotted actually). Neither the router nor either of the satellites show any connected devices. However, very infrequently the connected devices will show up in partial or total. Perhaps 10% of the time if I wait. Overwhelmingly, nothing shows. The Genie app, which Netgear is going to yank out Orbi support soon, does work. It is curious that your friend's purchase is recent and his app and your app works with the same version of the Orbi firmware at his siteand equipment. It would be worthwhile since your setups are so similar, to check all the settings and topology to see what dissimilarities are there (if any). Somewhere there is a bug, and it soulnds like maybe it is in system settings that is affecting the quality of information getting to the app. Inquiring minds would like to know.
- ekhalilJan 12, 2019Master
I guess that your friend does not have Sonos, right? ;)
- Can you please decribe how you are connecting the Sonos to Orbi. I see that you have a Connect and a Boost, I guess that these are both wired, right?
- Can we just test to disconnect all wired Sonos and see how the system behaves!
- Chuck_MJan 12, 2019Mentor
My friend DOES have sonos... the only part of the sonos system he doesnt have is a device called SONOS boost which off loads all the speakers onto a sonos network instead of the 802.11.
I removed the Sonos Boost (which was the only hardwired element) and refreshed the network... same behavior with no devices showing up
