wnnnbc
May 21, 2019Aspirant
Samsung 7 series tv will not stay connected to Orbi
Hey there, I have been having an issue over the past month that I cannot seem to fix. I connect my Samsung tv to my router and it will work just fine, and then randomly (anywhere from a few hours to ...
- May 22, 2019
wnnnbc wrote:
Hey there, I have been having an issue over the past month that I cannot seem to fix. I connect my Samsung tv to my router and it will work just fine, and then randomly (anywhere from a few hours to a few days) I will turn my tv on again after it being off for at least a few hours and it will say it cannot connect to my router. I have tried changing IP address settings, powercycling both the router and TV, but the only thing that works is resetting the network settings on my TV and then setting up the connection again like I did when I first got the TV. I have updated the firmware on both the TV and the router and I still seem to have the issue.
Does anyone have any ideas or is anyone having a similar issue? Thanks in advance
This is an indication that DHCP functionality is not working properly. Usually this is caused by a "bad" device in your network. Please look for such device. It can be a wifi repeater or another device acting like a wifi repeater.
Untill you find this "bad" device, I think you can workaround the issue and fix your TV's internet by assigning a STATIC IP address to the TV in the TV settings. This IP address needs to be outside the DHCP range set in Orbi LAN settings.
May 21, 2019Guru - Experienced User
Set a reserved IP address for the TV on the RBR?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
