ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
Dustin278
Aug 19, 2017Apprentice
Mattwookie is yours still stable? Just changing the SSID didn't work for me more than 30 minutes.. mine seems to have problems when walking through my home and it handoffs from router to satellite..
mattwookie
Aug 20, 2017Tutor
Dustin, my setup is still working great. no dropped connections that I am aware of. A little more detail on my process. 1. I updated the firmware of the sattelite and router. These need to be updated seperately. I had to manually download the update and install from my computer. 2. I unplugged the modem power and disconnected the ethernet going into the Orbi router. 3. I manually reset both the router and sattellite using a pin. Insert the pin into the reset hole on the back of the Orbi and hold it in for about 5 seconds. A light will start to blink when done. 4. Follow the instructions on the mobil app for a new installation. You will need the password from your label to get back onto the orbi wifi during setup. This process worked for me on my RBK50. I wish everyone the best of luck with this headache. BTW my S8+ is the unlocked version (not sure if this matters).
