tripleg
Jul 14, 2019Aspirant
Samsung Phones battery life sucks with Orbi
Since adding the RBR50 and 2 slave units my Samsung Phones (S8 and S5 and TabA's) all have horrible battery life. If I turn off Orbi and go back to the old AT&T Router and Mesh units the battery lif...
Jul 23, 2019Guru - Experienced User
My Galaxy Tab S2 doesn't exhibit this either...
- jaychuJul 24, 2019AspirantJust tried to factory reset everything before going to bed. Woke up with the same result. Going to try unplugging the rbw30 tonight. Any other suggestions would be appreciated.
- FURRYe38Jul 24, 2019Guru - Experienced User
Let us know how it does with out the RBWs online.
- Fl1ntstoneJul 24, 2019Apprentice
Hi,
What version of Android are you running on your Samsung devices? Is it also possible to check 'computed power use' on your Samsung devices?
CheerZ
