tripleg
Jul 14, 2019Aspirant
Samsung Phones battery life sucks with Orbi
Since adding the RBR50 and 2 slave units my Samsung Phones (S8 and S5 and TabA's) all have horrible battery life. If I turn off Orbi and go back to the old AT&T Router and Mesh units the battery lif...
jaychu
Jul 24, 2019Aspirant
Just tried to factory reset everything before going to bed. Woke up with the same result. Going to try unplugging the rbw30 tonight. Any other suggestions would be appreciated.
Jul 24, 2019Guru - Experienced User
Let us know how it does with out the RBWs online.
- Fl1ntstoneJul 24, 2019Apprentice
Hi,
What version of Android are you running on your Samsung devices? Is it also possible to check 'computed power use' on your Samsung devices?
CheerZ
- jaychuJul 24, 2019Aspirant
Fl1ntstone wrote:Hi,
CheerZ
Hi,
I'm currently using Anrdoid 8.1. OP is actually using a Samsung device, I'm actually on a Razer Phone. In the past I've attempted to flash my phone to Android 9 and I've experienced the same issue as well (before my rbw30 and was updated to latest firmware at the time). Not sure where to check computed power use but I've attempted to get battery logs a while back from adb. The root cause seems to be that somehow the router is interfacing with my phone in a way that prevents it from entering deep sleep and acting as if it were on. The only resolution at the moment is to turn off wifi at home but it wouldn't be quite ideal, especially if I have guests over and their phone dies as a result of the router.
Any help or suggestion would be appreciated !
- Fl1ntstoneJul 25, 2019Apprentice
Hi,
Certain versions of Android have had issues with WiFi draining the battery and this is the fix:
- Go to Settings > Location > open Menu (three dots, top-right corner) > select Scanning > Turn Off WiFi scanning.
- Go back to Settings > Backup and reset > Network settings reset > tap “Reset settings”.
- Reboot your device.
CheerZ
CheerZ
Hi,
- jaychuJul 25, 2019Aspirant
FURRYe38 wrote:Let us know how it does with out the RBWs online.
My battery dropped from 100% to 70%, though I suspect the reason the result was a bit better was because the wifi disconnected from time to time. I noticed it was disconnecting a bit this morning when I woke up. So I would have to assume now with the latest firmware, I am seeing the same issue.
- FURRYe38Jul 25, 2019Guru - Experienced User
And this is with the RBWs turned off?
So the samsung has been disconnecting and reconnecting form the orib?
Let us know if turning OFF the wifi scanning suggestion helps...
Try enabling and disabling of Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Is this the only device that seems to draing the battery?
FURRYe38 wrote:And this is with the RBWs turned off?
So I'm actually working from home today so I'm going to play around with this more. I have a spare OnePlus One that I can try and see if it exhibits a similar issue. The reason my phone is disconnecting (Razer Phone) is because I need the RBW30's to bring the signal upstairs. Without them, I only have signal on the 1st floor and basement. The settings you suggested are already in play, so at this point I'm going to try the wifi resetting suggestion. I'm really hoping this is just an isolated incident with my Razer Phone specificaly.
