tripleg
Jul 14, 2019Aspirant
Samsung Phones battery life sucks with Orbi
Since adding the RBR50 and 2 slave units my Samsung Phones (S8 and S5 and TabA's) all have horrible battery life. If I turn off Orbi and go back to the old AT&T Router and Mesh units the battery lif...
Fl1ntstone
Jul 24, 2019Apprentice
Hi,
What version of Android are you running on your Samsung devices? Is it also possible to check 'computed power use' on your Samsung devices?
CheerZ
jaychu
Jul 24, 2019Aspirant
Fl1ntstone wrote:Hi,
CheerZ
Hi,
I'm currently using Anrdoid 8.1. OP is actually using a Samsung device, I'm actually on a Razer Phone. In the past I've attempted to flash my phone to Android 9 and I've experienced the same issue as well (before my rbw30 and was updated to latest firmware at the time). Not sure where to check computed power use but I've attempted to get battery logs a while back from adb. The root cause seems to be that somehow the router is interfacing with my phone in a way that prevents it from entering deep sleep and acting as if it were on. The only resolution at the moment is to turn off wifi at home but it wouldn't be quite ideal, especially if I have guests over and their phone dies as a result of the router.
Any help or suggestion would be appreciated !
- Fl1ntstoneJul 25, 2019Apprentice
Hi,
Certain versions of Android have had issues with WiFi draining the battery and this is the fix:
- Go to Settings > Location > open Menu (three dots, top-right corner) > select Scanning > Turn Off WiFi scanning.
- Go back to Settings > Backup and reset > Network settings reset > tap “Reset settings”.
- Reboot your device.
CheerZ
CheerZ
Hi,
- Blanca_OAug 07, 2019NETGEAR Employee Retired
Hi jaychu
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
- jaychuAug 07, 2019Aspirant
Blanca_O wrote:Hi jaychu
Blanca
Community Team
Hi Blanca,
Thanks for the follow up!
To be honest, I'm kind of at a loss. I attempted to roll back to older firmware but the settings I changed via telnet was not saving my auto update settings and kept forcing auto update anyways. At this point I've given up and resorted to using data. It's not a good solution and i'm hoping for a resolution. Any suggestions would be greatly appreciated.
Thanks,
Justin
