Caiktin
Sep 19, 2023Aspirant
Samsung S22 Ultra phone connects to router internet but not orbi mesh system
Recently my S22 Ultra galaxy phone has started to drop out of internet constantly. Didn't always do this but I'm wondering if an update of some sort has affected it. I can connect directly from the ro...
Sep 19, 2023Guru - Experienced User
What Orbi model do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Be sure to disable any MAC Address randomizers on mobile devices:
