Caiktin
Sep 19, 2023Aspirant
Samsung S22 Ultra phone connects to router internet but not orbi mesh system
Recently my S22 Ultra galaxy phone has started to drop out of internet constantly. Didn't always do this but I'm wondering if an update of some sort has affected it. I can connect directly from the ro...
Caiktin
I'm sorry I'm not very tech savvy so just trying to wrap my head around all the jargon. It's funny that you mention Mac address though because I was fiddling with my settings to see if anything would help and it did make a difference when I swapped from randomised MAC to phone MAC which seemed to fix the problem. Question is, is it safe for me to keep it this way or could it potentially cause other issues for me? Is there a better solution like perhaps swapping it back and rather chasing the access control through orbi instead?
Sep 20, 2023Guru - Experienced User
When you at HOME, yes, it's safe as the device is only connecting to your HOME router system. I keep mine disabled at home.
Enable the randomizer when your traveling away from home. It's when your traveling or using some coffee shop, airport or retailers Wi-Fi that maybe not secure, that you would want the randomizer enabled on your mobile devices here.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
