sgrayban
Jun 26, 2018Apprentice
Samsung S7 wifi connects but no internet available
I have a Samsung S7 G930V and since the last router update my phone randomly drops connection and no internet available. For the life of me I can't figure out why. I have changed the 5G channel and...
sgrayban
Jul 03, 2018Apprentice
ISP is CenturyLink
Zyxel C3000Z double bond
I do a erase after I downgrade ?
Jul 03, 2018Guru - Experienced User
ALL radios disabled on this modem to be sure?
Yes, load the FW file and let it process. Then ERASE and set up from scratch. IF your using the Orbi in AP mode, I would disconnect it from the modem right before you select the ERASE. Just keep one wire connected PC with the router is all. Turn off or disconnect ALL other devices. Once you get the router ERASED then set up from scratch an reconfigured for AP mode, then reconnect back to ISP modem and all other devices.
- sgraybanJul 04, 2018ApprenticeDowngraded the firmware yesterday and all working great then woke up this morning and friggin router auto updated to the **bleep**ty new version and back to flaky Wi-Fi access.
