btwsales
Jun 19, 2020Aspirant
Samsung says wifi is connected but ORBI says it is NOT?
Samsung QN55Q60RAFXZA all indication says WIFI is connected but signal is not strong enough as the only way to access SMARTHUB was with my iphones hotspot Net gear C7000 Orbi RBR50 and 2 sateli...
- Jun 19, 2020
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy.
Jun 19, 2020Guru - Experienced User
do you have the wifi on the C7000 running?
Is the Samsung connected to that?
The C7000 is a modem/router combo device. Do you have it in modem only mode? or the Orbi in access point mode?
Otherwise you're running 2 routers in router mode on your network which can cause a double nat.
btwsales
Cable is in the C7000 ethernet cable is in the RBS , ethernet cable from RBS to imac - 2 satelittes
17 devices connected to ORBI running just fine
Samsung says connected to wifi but the smarthub will not work and this 1 TV is not anywhere located in my ORBI devices on the app or Admin login on desktop.
When we trouble shot the smarthub the lady had me connect the TV to my iphone HOTSPOT and boom it worked instantly
- plemansJun 19, 2020Guru - Experienced User
btwsales wrote:Cable is in the C7000----The coax cable? ethernet cable is in the RBS-----do you mean RBR? RBR is router and RBS is satellite. The router? , ethernet cable from RBS---- truly from the satellite? And how is the satellite connected to the rbr wireless or wired? the rbs to imac - 2 satelittes
This was kind of vague. So down to basics.
1. Is the wifi running on C7000?
2. Do you have the c7000 in modem only mode or bridge mode?
3. Did you disconnec the samsung from your phone and redo your internet connection for the tv?
What error is it giving you?
- btwsalesJun 19, 2020Aspirant
my bad COAX is in C7000 yes . an ethernet is in RBR to imac (not on wifi) the 2 RBS in the house are wireless
1. don't think so ?
2. good question, just tried to login into routher but will not accept the serial number on it
3. yes - The server is under maintainance error 60
- FURRYe38Jun 19, 2020Guru - Experienced User
Check the mode of the C7000 modem, connect a wired PC to the modem and log into the modems web page at 192.168.100.1.
Navigate to Advanced Tab, Adminstration, Router mode. You may see Yes or Not or NAT mode, Enable or Disable. If you see router or NAT mode set to Yes, then the modem is working in router mode. This should be set to NO or disabled to get the modem to modem only mode.
