TomMac
Dec 15, 2016Guru
Sat still dropping out , but only on Ipad
Running the Orbi and one Sat on latest sw, single floor home, sat is aprox 35 ft away from main... data thru put is good, getting same speeds as main unit.
But, Seeing a streaming problem only ...
- Dec 19, 2016
Thanks Tom for testing this if anyone else is having issues with the .18 Firmware let me know so I can pass the issues to the engineers.
DarrenM
DarrenM
Dec 15, 2016Sr. NETGEAR Moderator
Hello TomMac
I have seen some other posts about Apple products having issues with orbi did this just start happening to you after upgrading to the latest Firmware?
DarrenM
TomMac
Dec 15, 2016Guru
Hi Darren...
It does seem to be more apparant with the latest version of sw, tho not sure if it also occured with the last version.( they were a 10 days or so apart )
