pcarpenter
Mar 13, 2023Initiate
Satelite firmware update
Have RBR50 w/ satelite that has worked well. After app update, I can no linger see the satelite on the network map via app. Two questions: 1) How can I see my network map from my desktop/laptop ...
Mar 13, 2023Guru - Experienced User
Try logging in through the browser and checking the attached satellite. It wouldn't be the first time I've seen the app display it wrong.
You can also try auto-updating through the browser as well.
And if that doesn't work, you can manually update that method.
- pcarpenterMar 13, 2023Initiate
That's my question. How do I log in through the browser and check the attached satellite? I see no way to do so on the Netgear webpage
- plemansMar 13, 2023Guru - Experienced User
try orbilogin . net
or its ip address.
The default is 192.168.1.1
It could be different if you're in a double nat (your modem/gateway isn't just a modem)
