pcarpenter
Mar 13, 2023Initiate
Satelite firmware update
Have RBR50 w/ satelite that has worked well. After app update, I can no linger see the satelite on the network map via app. Two questions: 1) How can I see my network map from my desktop/laptop ...
pcarpenter
That's my question. How do I log in through the browser and check the attached satellite? I see no way to do so on the Netgear webpage
Mar 13, 2023Guru - Experienced User
try orbilogin . net
or its ip address.
The default is 192.168.1.1
It could be different if you're in a double nat (your modem/gateway isn't just a modem)
